Get the Ultimate M7 Speed Strut Tower Brace For Your MINI!
https://cimg1.ibsrv.net/gimg/www.6sp...f941d23590.png MINI Folks! Get The M7 Strut Tower Brace today and qualify for FREE shipping! If you are concerned about strut tower mushrooming and looking for improved handing, then the M7 Strut Tower Brace (STB) is the answer. This is the ONLY strut tower brace on the market that features anti-mushrooming technology. Over and over we've heard the same complaint: the strut towers mushroom after heavy impacts from the shocks and low aspect ratio tires. At first glance the shock towers take on a barely visible convex shape, but if you compare it to the original sheet metal, you would find the horizontal plane has been moved as much as 3/8" upwards, throwing the suspension out of any possible alignment fix. The problem will most likely show up as a slight pull either left or right depending on which strut tower is buckled. The end mounting plates of the M7 Strut Tower Brace will solve this problem by sandwiching the sheet metal and shock top plate, creating a reinforced surface that will not bend, even during hard impacts. The M7 STB features 1/2" (13mm) thick end plates that add extra strength to the strut towers and prevent mushrooming and potentially costly repairs. The cross brace greatly improves handling by adding torsional stiffness to the front body structure. This helps keep your tire planted on the ground and pointed in the direction you want to go, especially during hard turns. Machined from billet aluminum and matte black powder coated, the M7 Strut Tower brace features a durable black finish that looks great and will not chip or oxidize. Concerned about clearance? No worries. The M7 STB profile is designed to clear both stock and aftermarket cold air intakes & ECUs. The strut tower brace's modular design allows easy access to the oil filter or any other accessories that might normally be blocked and require removal of the entire brace. If you have performance driving in mind, the M7 Strut Tower Brace is what you're looking for! Strut Tower Brace Fitment - Cooper S (2002-08) (R52 & R53 "S" Models) Strut Tower Brace Fitment - Cooper S (2007-14) - Cooper S Clubman (2008-14) - Cooper JCW and Cooper JCW Clubman (2009-14) - Cooper S (2007-14) - Cooper S Clubman (2008-14) Countryman MONSTER Strut Tower Brace Kit Fitment - Cooper Paceman, Cooper Paceman JCW ALL4, Cooper Paceman S and Cooper Paceman S ALL4 (2013-14) - Cooper Countryman JCW ALL4 (2013-14) - Cooper Countryman, Cooper Countryman S and Cooper Countryman S ALL4 (2011-14) Strut Tower Brace Fitment - Cooper S Coupe and Cooper S Roadster (2012-14) - Cooper JCW Coupe, Cooper JCW Roadster, Cooper S Coupe and Cooper S Roadster (2012-14) https://cimg2.ibsrv.net/gimg/www.6sp...99e57314cd.jpg |
