Paceman ECS Stainless Brake Rotor Set Screw
http://www.ecstuning.com/forum/bmw/ecs800header.jpg MINI R61 Paceman ECS Stainless Brake Rotor Set Screw Have you ever tried to remove the brake rotor set screws on your MINI? If they are showing signs of corrosion, a failed attempt at removing may result in a screw that needs to be drilled out. ECS Tuning is proud to introduce our very own solution to this problem. We have designed a stainless steel rotor set screw that will not seize up! Because of its stainless steel composition, our set screws will be easy to remove for years of trouble free use, unlike the OEM part. Made from stainless steel. No more seizing. Fits : R61 MINI Paceman /S/SX/JCW (2013+) http://www.ecstuning.com/marketing/M..._Set_Screw.jpg Click HERE for ECS SS Rotor screws or for more information. |
