R50 R52 R53 MINI Cooper (7/2006+) ECS Wheel Spacer Kits
http://www.ecstuning.com/forum/bmw/ecs800header.jpg R50 R52 R53 MINI Cooper (7/2006+) ECS Wheel Spacer Kits 3mm-20mm sizes Wheel spacers are a great way to get the look you want from your wheels. Set up a more aggressive stance by pushing the wheels out from the body. The hubcentric units can also serve as a cure for wheel rubbing when utilizing an aftermarket suspension setup. ECS offers a wide variety of sizes to give you the exact look you need - choose the ideal stance for your specific needs and tastes. Every ECS spacer is made from a high quality aluminum to keep weight to a minimum and effectively resist corrosion. Stance Out! Fits: R50 MINI Cooper (7/2006+) R52 MINI Cooper Convertible /S/JCW (7/2006-2008) R53 MINI Cooper S / JCW (7/2006+) http://www.ecstuning.com/marketing/M...CS_Spacers.jpg Click HERE For spacer kits |
