R53/2 Water Pumps In Stock Now! by Pelican Parts
In the case of the MINI Cooper S, the water pump is driven off the end of the supercharger. This setup is a bit different than most cars where the water pump is driven off the engine belts. When a water pump begins to fail, you’ll notice that the car tends to overheat at low engine speed, such as sitting at a stoplight. When you accelerate, the engine temperature will drop. Now, this is not always indicative of a water pump, but a good starting point.
We offer genuine MINI water pumps - you can shop HERE We also offer a Water Pump Super Kit for both manual & auto transmissions: -Water Pump and Gasket -Thermostat -Thermostat Housing Gasket -12 oz. Redline Water Wetter Corrosion Treatment -1 gallon of OEM MINI Coolant (must be mixed with distilled water) -Expansion Tank or Thermostat Housing Cap -Upper and Lower Radiator Hoses Super Kits are listed HERE Need help to guide you through this project? Check out our step-by-step DIY article: R53 Water Pump Replacement Mark/Pelican Parts |
