Serpentine Belt Replacement This Weekend! By Pelican Parts
It’s always a good idea to check your serpentine belt at every oil change for cracks which would be visible on the underside of the belt. This belt is very important as it drives accessories such as water pump (non-S), supercharger/water pump (S), alternator and A/C compressor. If you discover that your belt needs to be replaced, we have you covered!
Shop for Contitech serpentine belts here! And don’t forget to check your tensioners at the same time. Need assistance with the replacement process? Review our install instructions: Replacing The Serpentine Belt On Your MINI Mark/Pelican Parts |
| All times are GMT -5. The time now is 02:13 AM. |
