-   -   SneedSpeed Mini R53 Front Splitter (https://minicooperforums.com/forum/member-group-special-buys-27/sneedspeed-mini-r53-front-splitter-9483/)
sneedspeed Oct 24, 2016 01:46 PM
4 Attachment(s)
Fully adjustable race front splitter with integrated under tray, allows adjustment of front down force for driver and track needs.
This splitter is specifically designed for the R53 MINI S and JCW front bumper to provide max down force, reduce drag and improve engine power. The integrated under tray provides engine compartment air scavenging for higher down force and reduced engine compartment temperatures. Also, creating more power and reducing drag over the factory setup resulting in higher top speeds. The tray creates a skid plate under the front of the car, protecting the radiator and front of engine from debris. Extra wide splitter design smoothes air flow at front tire to farther reduce drag. Splitter attaches with fully adjustable super-duty aircraft grade aluminum stanchions, aluminum and steel brackets and heavy duty fasteners.
Insight:
-Fully adjustable for aero tuning and track conditions
-The splitter extends approximately 3 inches in front of the bumper and to -the outside edges of the front tires
-Extends rearward to front sway bar
-Kit comes with all the hardware needed for installation.
SneedSpeed splitters now carry a full 100% replacement for life with the original purchaser. If you somehow break a SneedSpeed splitter send us the pieces you have and we'll send you another one FREE!! This is only for the splitter and doesn't include hardware or stanchions.
