-   -   SneedSpeed Spec Clutch Kit and Lightened Flywheel (https://minicooperforums.com/forum/member-group-special-buys-27/sneedspeed-spec-clutch-kit-lightened-flywheel-9331/)
sneedspeed Aug 22, 2016 09:04 AM
2 Attachment(s)
Spec Clutch Kit- A carbon semi-metallic 6 puck sprung hub disc that has been the leading puck clutch in drivability, life and torque capacity. This unit is designed for street and race cars that require an aggressive but streetable engagement and high torque capacity. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Also available in 3 puck configuration. Great for street, drag, road racing, pulling, rallye and drift.
Lightened Flywheel- MINI R53 lightweight aluminum flywheel with replaceable friction disc. We have been using lightweight flywheels in all our cars for over 10 years, they are one of the best mods you can do when you replace your clutch. By reducing the weight of the flywheel the motor can rev quicker causing faster acceleration of the car. We have found the lightweight flywheel to be repeatedly 2 tenths of a second and 1 mph quicker than the stock flywheel on an 1/8 mile drag strip.
Spec Link: spec clutch mini cooper
Flywheel Link: R53 MINI S Lightweight Aluminum Flywheel
