-   -   Is Your Fuel Pump Noisy or Clicking? May Be Time To Replace It / DIY by Pelican Parts (https://minicooperforums.com/forum/member-group-special-buys-27/your-fuel-pump-noisy-clicking-may-time-replace-diy-pelican-parts-6165/)
PelicanParts.com Apr 25, 2013 12:44 PM
Some common fuel injection problems can be traced back to a faulty or non-operational fuel pump. If your pump is noisy and loud or the fuel pressure in the engine compartment is below what is needed for proper fuel injection operation, then it’s probably time to replace it. The fuel pump is a not as simple a device as one might think. The fuel actually runs through the pump and acts as a coolant and lubricant for the entire assembly. Therefore, if you let your car run out of gas, make sure that you turn off the pump immediately or you might damage the internal components of the pump. Trust me—not much is worse than a broken or faulty pump leaving you stranded on the side of the road.
This is a straight-forward DIY project which you can complete within two hours.
Check out the article here -> MINI Fuel Pump & Filter Replacement
http://im1.shutterfly.com/media/47a3...D550/ry%3D400/
