2011 Mini Cooper S Convertible
Hi everyone,
I have a 2011 Mini Cooper S with bi-xenon headlights. The other day, the Right Side headlight just stopped working. I wanted to see if the light was at fault or it was an electric issue. I swapped the Right Side light bulb with the Left Side and it worked!!! So now I need to figure out what's wrong with the Right Side Headlight. Here are the possible options: (1) Fuse blown (2) Head Ballast unit not working (3) Internal Wiring (4) Other Any feedback in this matter would be great. I know where the fuse box is but I don't really know which fuses belong to what. The owner's manual just says do not replace fuses on your own go to the dealer. I hate going to the dealer because they make you spend boat loads of money for simple things that anyone with a little knowledge can do. |
