Brake lights do not work
Old Oct 15, 2010 | 02:02 PM
machine's Avatar
Default Brake lights do not work
Hi everyone, just wondering if you could help.
I have a Mini Cooper 51 plate and the brake lights have stopped working yet the tailgate light still works.
I've checked:
The fuses,
Brake light switch,
Bulbs,
Brake res electrics.
And still they don't work. Could this be an earthing fault or ECU fault?
Anyone had this problem?
It seems its one thing after another with this car, i've only just had the wiper motor replaced costing me a packet!
Thanks in advance.
Old Oct 17, 2010 | 06:53 AM
drifter28's Avatar
did you check the bulb socket? It might have a bad ground on it. I think the 3rd brake light works off the same fuse. Hold the bulb up to the light and flick it with your finger to see if the filament shakes. Sometimes it's hard to tell just by looking at it.
Old Oct 17, 2010 | 12:02 PM
Check for VOLTAGE at the tailight socket , no voltage work backward check that one side is grounded properly
scienceesl
Aug 24, 2015 11:37 AM
Keoki
Sep 24, 2012 07:17 PM
bigcheez
Jul 23, 2010 11:33 PM
pedrok
Jan 25, 2009 07:59 PM
miniguy01
Nov 11, 2007 04:09 PM
