Software
Dinan Performance Engine Software
2002-05 Mini Cooper S Price: $299.00 Labor Units: 1/2 hr ( can only be done at an authorized Dinan dealer ) Emission Status: 49 State Emission Legal Peak Horsepower: 175 @ 7000 rpm Peak Torque: 158 lb/ft @ 4500 rpm Point Value: 2 ( when you total 10 points you recieve a Dinan deck lid badge which you cant buy from them ) Improved throttle response, a 300 rpm rev-limit increase and MORE POWER! Dinan's Performance Engine Software bumps peak output to 175 hp @ 7000 rpm and 158 lb/ft torque from engine management tuning alone. In addition to the increased power, the software provides a 7300 rpm rev-limit, allowing you to carry more road speed in each gear as well as optimize shift points. Revised EML tuning provides more immediate throttle response and improved high performance drivability as well. And at $299, Dinan's Performance Engine Software for the MINI represents quite the bang for the buck! Additional stages of engine software are available for optimum performance from specific combinations of Dinan Performance Products for the MINI Cooper S. Check www.dinancars.com for your local dealer and other products that are available for these killer go-karts. With just simply bolting on a Intake box and exhaust with this software you will see power around 185hp, and with there boost kit you will bump it up to 210hp. |
RE: Software
Wow. I wish I had money....
RE: Software
What do you have done to your car so far if anything?
RE: Software
Nothing yet. Right now I'm working on a Civic as a project car. When I finish the Civic, I'll sell it and have plenty of money to buy a new project car or beef up the Mini.
RE: Software
What are you doin with the civic.........my friend just dropped a b18 c5 in his whip and did it up pretty nice so far.
RE: Software
That's exactly what I'm doing. However, if I can dig up a couple extra dollars, I'll drop in a b18c1 and get a turbo that'll run around 10-12 psi.
RE: Software
thats about all i know with honda....cant stand em. but i have sum friends with sick ones that run hard. A friend of a friend has a 90 hatch with a b18c5 and a huge turbo boostin like almost 20psi...ud never know this car had anything with the primed paint and red spray can rims....all i know it runs real hard against my friend vinny's EVO which runs in the 11's
RE: Software
That much boost in a c5? He must be running like 150 octane gas to do that. That's why I'm going to a c1 if I boost, because it's got lower compression.
RE: Software
nah....he's runnin pump gas....i may be off on the boost
RE: Software
I'm guessing he's probably got forged internals if he is running that much boost though.
| All times are GMT -5. The time now is 02:02 AM. |
