Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Bump steer
Old 03-19-2018, 08:22 PM
Fred Briggs's Avatar
Default Bump steer
I'm fairly new to the Mini life so I'm wondering if big time bump steer in normal or should I be checking into some suspension work? Stock R56 that has been aligned recently. Thanks.
Old 04-21-2018, 01:54 PM
In case anyone is following this thread, I replaced the struts & the car is behaving much better concerning bump steer. The DS front strut had zero damping left going up or down!
