18 inch rims for for 2006 cooper s
Is it possible to used 18 inch rim on 2006 Cooper S without modification. Please advise.
I'm runing them ... 215/35/18 tires
Got an a 2009 S convertible with stock !6" rims. Will 18" work and what's the largest tire I can use and still stay under warranty. I may go to conventional tire instead of run flats. Would the sizes change depending on which tire I select. Thanks, Bob
I'm running 215/35/18
I'm just about ready to start my upgrade process from 16" to 18" rims and tires.
More questiones: Knowing I will need to install turning stops, will there be a big loss in the cars turning radius? I'm going with a non OEM rim 18X7 with a 52mm offset. OEM {John Cooper Works 18" rims} come with a 52mm offset. The dealer says the OEM rim will fit my 2009 S convertabile. I hope the mail order non OEM rims will also fit. I leaning towards the OEM tire size of 205/40R18 just to be sure all fits in the wheel well. I'm not doing run flats. Leaning towards Michelin Pilot Sport PS2. Any comments on my plan? Thanks, Bob. |
