air sensor
Can I disable the sensor so I can do away with the unit in the tire?
If you are using run flat tires absolutely not
they are designed to have air ,if they are flat they will look normal but should only be run 100 miles without sensors you will not know they are flat and have a catastrophic tire failure |
I am switching to conventional tires on different rims
What year do you have ?
| All times are GMT -5. The time now is 01:47 AM. |
