Ordering brakes online; need advice
I am ordering brakes and rotors online for my 2007 Mini Cooper S Turbo (6 speed). Need to know what to order. I think I need Wagner (4-stud wheel) and Wagner Thermo Quiet (semi-metallic), but need to know if that is right. I also need to know if I should replace the brake sensor. If so, what type do I need to look for? Never done this before, but trying to save money.
We carry many pads and options. Some websites show the 2007 MINI as the first gen R52 MINI convertible which has different pads, so make sure you have the correct pads.
We have the correct pads below. Click here for your 2007 R56 MINI Cooper S options. Also make sure you have the stock brakes and not JCW version 4 piston brakes. Select front and rear pad sets or choose your own matched combo. Then select one front brake pad sensor and one rear pad sensor. http://www.ecstuning.com/Mini-2007-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Braking/Pads/ We do carry Vaico brand for another option. The brake pad sensor , there is one in the front left and one in the right rear. We carry many options based on prices. Thanks |
| All times are GMT -5. The time now is 06:46 AM. |
