Rotor Replacement
What size is the Torx bolt that holds the rotor on on an 05 cooper S ?
Torx head size T50 .
The bolts should be replaced every time you do a brake job / rotor change and you can apply the anti seize to the head of the brake rotor screw. One rotor screw per rotor. http://www.ecstuning.com/Search/07136772426/ES16458/ http://c1552172.r72.cf0.rackcdn.com/362885_x600.jpg Thanks and let me know if you need anything else. |
