Run flats to regulars
I need to replace all the tires on my 2007 Mini S. I would prefer to put on regular tires instead of run flats. Is there any impact on Mini tire monitoring software I need to know about / fix?
NO TPMS operates as designed/
You need to address in case of a flat , Tire Mobility kit , Fix a flat , tire plugging kit , small air compressor ect . Or a AAA card for free towing in case of a flat |
excellent, thanks v. much for the advice. Other than dealer, is there a preferred place for having front brakes replaced?
Brakes are easy takes me 1/2 hour
Any Brake shop could do it |
