Tire Sizes
Tire Sizes
I have a 2010 Mini Clubman with stock wheels and tires (175-65 x 15).
I would like to put a 195-60 x 15 on as a replacement. The height and width is not a huge difference, but has anyone tried? Any issues? Al
Hello... you will not have a problem. the car has plenty of clearance to accommodate your 195 60 15. The 175 65 15 you have now is approx. 23.97" in diameter and approx. 6.89" wide. The size you want is approx. 24.21" diameter and approx. 7.68" wide. If you had the 17" tire option on the car you would have a 205 45 17 which is approx. 24.44" in diameter and approx. 8.07" wide. Both numbers on the 17" option are larger than the one you want to go with so you are good to go. Good luck with it!!
