wheel change and sensor reset
Old Mar 14, 2009 | 11:24 AM
pcowle's Avatar
Default wheel change and sensor reset
i put some older mini wheels on my 2009 cooper and they do not have the sensors so i keep getting the alerts on the dash about tire pressure. it does not reset. is there a way to over-ride this and turn off the warning?
Old Mar 14, 2009 | 01:49 PM
The 05 sensors are different then the 09 and NOT compatible with each other ...
You can do the following things:
1) Remove the TPMS sensors from the 09 wheels and mount them in the older wheels
2) Purchase a set here : http://www.tpmssource.com/(S(4nsduz3.../AppGuide.aspx
3) remove the bulb from the dash and ignore the low pressure light
terencekent
Jan 19, 2018 06:27 PM
theateist
Jun 24, 2015 11:54 AM
Edvan737
Oct 28, 2010 03:16 PM
lawddf
6
Feb 14, 2009 03:41 PM
jon.hill@sbcglobal.net
Feb 6, 2009 09:13 AM
