Occasional Hard Starting
Old Nov 23, 2008 | 09:50 PM
bogus's Avatar
Default Occasional Hard Starting
Good evening,
I am normally a Corvette guy (run a Corvette site), however, a co-worker is having a hit/miss problem with her 2007 Cooper S convertable.
It goes like this: Start the car (hot or cold) and it runs very rough with little power. Turn it off, restart, all is great.
She has had it to the dealer a couple of times for this, but they haven't been able to isolate it. My guess is a reflash of the ECU... but I would like to think the dealer did that first.
Has anyone else ever had this problem?
Thanks!
- Andy
PS: Nice looking site!
Old Nov 28, 2008 | 03:32 AM
bean's Avatar
Default RE: Occasional Hard Starting
Hi Andy,
Someone tried to sell me a 2003 mini before and i got turned off due to the hardstarting problem... worse yet it did not want to start, we checked overflowing fuel it might have been flooded due to stepping of the gas even if the car's engine hasnt started yet... anyway the problem was immediately solved because we found out that the FUEL PUMP is worn out already... please try checking that... hope your mini goes well...
-jojo
Old Dec 6, 2008 | 12:49 PM
bogus's Avatar
that does make sense... if the fuel pump is like many of the other modern EFI fuel pumps, it has a built in check valve... things get really wacky when that check valve fails... it might not be generating enoug pressure at startup.
I will forward this off to the owner.
Thanks!
surferian
Jul 14, 2018 01:20 PM
PeterT
May 18, 2013 06:12 PM
burples05
Oct 29, 2012 10:24 PM
MINIman1187
Dec 11, 2011 01:28 AM
minikev
Apr 3, 2008 07:58 PM
