Over Heating! Please help!
Old Nov 11, 2010 | 10:42 PM
Texas_Mini's Avatar
Default Over Heating! Please help!
My mom has been having issues with her car getting hot! I checked the fluids in the over flow it was bone dry so I add some to the max line. Its still getting hot. She can drive about 5 - 7 blocks and turn the car off and the fan will kick in like it is over heating. I am good with cars but cant figure out why it only gets hot when sitting still. Once she gets moving the temps come down and the car seems to be fine!
Additonal note: The trunk/hood light comes on when I unlock and open the door. It comes on for 5 seconds and goes off!
Old Nov 12, 2010 | 07:03 PM
Texas_Mini's Avatar
Bump!
Any one on here had the same situation, she doesnt have the funds to take it to the dealership or an indy mechanics so I need to fix this myself!? Might some one have a manual or any kind of help!
Thanks a million in advance!
Old Nov 12, 2010 | 08:15 PM
It's a normal cooling system... Check the easy stuff first , thermostat and radiator cap
Also check for leaks ... You might have a bad hose/clamp . Did you check the Oil for signs of coolant ?
Old Nov 14, 2010 | 02:38 PM
Texas_Mini's Avatar
Do they have electrical thermostats? I was told they might by a local inspection shop.
Old Nov 14, 2010 | 06:20 PM
http://www.penskeparts.com/DiagramsM...4&rnd=06222010
http://www.penskeparts.com/DiagramsM...png?v=06222010
scrill down shows standard thermostat
there is an electronic thermost to turn on the fans
Old Sep 18, 2011 | 08:51 AM
Sblumenthal's Avatar
Default Running hot
Hi. I'm having a similar issue--temp gauge is on high and fan runs after i turn off the car. I was very low on coolant and put more in. Unfortunately, that did not correct the problem. Is there any simple fix. Will it hurt the car if i drive it to my mechanic, approximately 20 miles away?
Thanks for your help!:mad
Arron Penfold
Mar 13, 2017 03:54 AM
rogerv
Mar 9, 2015 11:49 PM
klgrayson
Oct 7, 2012 07:51 AM
Shaggylocks
Jan 29, 2011 07:56 PM
stevied
Jan 12, 2009 06:23 PM
