Coolant problem need help!
Hi guys , i'm new here... and i hope so that someone will help me
Like first i own mini cooper r53, BY 2004..... car have 150 TKM ( app 100K miles)
I have fev problems with coolant sistem...
Few weeks ago in midle of drving i turned heating on and my expansion tank exploded ( separated on 2 peaces ) so i took my car ( not driving) to the shop and they find that i need to replace expansion tank and radiator and heater core ( expansion tank blowed because heater core was sealed ). reasons is becaose preowner putt pure water in cooling system ....
so i changed Radiator,expansion tank, heater core and three watter plastic separators. put mixture 60 coolant 40 water. and bleeded systerm.
Tested agein, drived few days i have great heating then today i kicked "pedal to metal" and approx at 5500 rpm in second gear steam come from hood immediatley stopped and turned off car... i looked under hood and i find that shoort hose that runs from branches to watter pump is broken....
So if someone can help me can broken water pump can cause rupture on hose
and also i checked ther is noo milk cremy on oil cap or expansion tank cap, there is no bubless in coolant no oil&coolant mixture , no foamy look at dipstic or gasoline smell in oil , no white steam from exoust ------ also there is no overheating... radiator fan work it kick on 105C ...
If anyone have idea what can cause this mess ?
daytripper540
10-27-2016 11:21 AM
Kalinchuk
10-13-2010 09:29 PM
