ASC sign keeps lighting, what could be wrng?
Old 01-30-2009, 06:06 AM
jetblackmini_dubai's Avatar
Unhappy ASC sign keeps lighting, what could be wrng?
Hi, Im a new member to this forum. I drive a r50 mini cooper 02'.When i drive for a while, The ASC lights gets turned automatically on and cant be turned off. Wht could be the issue?
Old 01-31-2009, 01:07 AM
rkiller69's Avatar
Default ASC light
from my past experience there is 2 things that might have happened
1) the ASC cable is ripped
2) you could have gone into a pothole, my frineds did that to their BMW 3-series coupe
their traction light went on and off
your best bet is to go to a mini cooper dealer and tell them that ur ASC light wont go away
hopefully the mini u got still has warrenty
Old 01-31-2009, 05:10 AM
Default ..
Thnks ..i guess i better tak my bbaby to the dealer!
Old 02-17-2009, 11:25 AM
Also check that the tires are properly inflated ... A low tire can make it sense wrong
Old 03-04-2009, 10:11 PM
Faria's Avatar
Your ABS harness connector plug (pin contacts) have corrosion wiggle the harness and cycle the ignition if it works --- clean corrosion in pin connector plug/ socket warning do not pry on female side pins, if they widen they won't contact properly male pin contacts.
If it does not work: Your ABS module has internal damage and will need repair/rebuild/and or replaced which needs software and aligning
reynold22
06-15-2012 02:29 PM
SuperchaR53ger
03-10-2009 10:15 PM
skcoop
04-14-2008 04:09 PM
zosim
01-01-2008 07:39 PM
miniholic
10-22-2007 11:53 PM
Quick Reply: ASC sign keeps lighting, what could be wrng?
