2007 Base model N14 P0366 Code Help!
Old Jul 22, 2019 | 10:46 AM
EMPIR3's Avatar
Default 2007 Base model N14 P0366 Code Help!
I have a 2007 Mini Cooper Base model N12. The car lost timing due to low oil pressure about a month ago and after completing multiple repairs we are left with a P0366 code that will return consistently on the second engine start after clearing the codes. The issue we are having is every possible reason we can think of has been investigated. Hoping someone here has some wizard magic or something. I apologize if the to-date summary is long, but really want to be comprehensive to answer some of the basic causes right off the bat.
Summary:
Originally, the car lost timing and died due to low oil pressure and was towed to my shop immediately. Exhaust cam was almost 90 degrees off time. Only code read at the initial scan was a P0302 misfire.
We replaced the entire timing chain assembly and tensioner (https://new.minimania.com/part/G2NME...-R55-r61-Non-s). Replacement was done to a tee (been checked 2 more times since out of total bewilderment as well) exact torque specs followed and cam/flywheel locks used during the replacement.
During reassembly, we noticed the brake vacuum pump drive plate was cracked. we ordered a new one (7570813) and replaced this as well.
After finishing the reassembly and on the second engine cycle the P0366 code set. We assumed it was a bad sensor. Swapped the intake and exhaust sensors and the code stayed on the exhaust side. Disconnected the sensor entirely and we got a P0365 code instead. Took voltage readings at the harness to compare with the intake and they both read the same. Sensor has 12 volts, 5 volts, and ground as compared to the intake sensor.
Our last guess was that the vacuum pump put too much torque on the cam itself and miss-aligned the end of the cam that is compressed on the assembly where the sensor reads. Took a degree measurement of the sensor reading surface at 90 degrees before TDC and matches up perfectly with the angle given of a new cam.
If it helps start the conversation in the right direction, the only part of the exhaust cam assembly that has not been replaced is the camshaft adjustment unit (7536085)
. We also don't think it is a PCM issue given the circumstances of the code, but i am out of ideas now.
Thanks to anyone who has some thoughts
califresh119
Mar 19, 2025 12:50 AM
dlockwood54
Nov 17, 2019 08:51 PM
KusoBabA
Nov 13, 2019 06:11 PM
StanP50
Sep 18, 2019 07:33 AM
colonelangus
May 19, 2019 10:27 AM
