2006 S Weird Shift from 3/4 A/T and P0734 Code
Old Dec 22, 2019 | 12:02 PM
califresh119's Avatar
Default 2006 S Weird Shift from 3/4 A/T and P0734 Code
Hi there,
First off, thanks to all the people that make this forum available and manage it. That is awesome and takes a ton of work.
Straight into it.
2006 Mini Cooper S w/ 85,000 miles. I was gifted it due to it having "transmission problems". I got in it and drove it and it seemed to drive fine, but then after driving a bit I realized that when at 20-30% throttle it would have trouble shifting from 3rd to 4th gear. Sometimes it would just completely drop off and redline the engine, and other times it would clunk into fourth hard.
Ways to get it to shift--
Driving full throttle
Using the sport shifter
Backing off the throttle
Threw a PENDING code for P0734 (Gear 4 Incorrect Ratio)
My question to all you Guru's is:
Can I replace that one shift solenoid? Does anyone have one they can send? What should I be looking for? I already changed the fluid with 4 new quarts and it didn't seem burnt badly. No metal shavings etc.
Tips and tricks greatly appreciated.
Here is a video I took of it doing it... Like i said driving hard full throttle it usually shifts just fine. It is the cruising around town where it won't shift right.
Old Mar 19, 2025 | 12:50 AM
irTruckr's Avatar
Default Oh My Gawd! same!! 4th gear slip fault code failed emission.
Wondering is a solution other than giving up was found. I have a new to me 2009 and the same issue. HELP please and thank you
ps sorry i have no info to share as im new to a mini
TruckerSteve
Originally Posted by califresh119
Hi there,
Straight into it.
https://youtu.be/Wa46ddDjp8M
dlockwood54
Nov 17, 2019 08:51 PM
KusoBabA
Nov 13, 2019 06:11 PM
StanP50
Sep 18, 2019 07:33 AM
EMPIR3
Jul 22, 2019 10:46 AM
colonelangus
May 19, 2019 10:27 AM
