2007 Mini Cooper s Convertible Stuck Closed
Hi! The top on my 2007 Mini Cooper S is currently stuck closed. The last time it came down, it appeared to had come down a little skewed and caused the pin on the driver side to miss to mounting hole.by about 1 inch and now it is wedged to the side of the windshield. It doesn't move when I try to re-open it, The sunroof doesn't even move, although I I think I heard the sunroof motor trying to move. I think the reason why the sunroof is not moving is because the rail is slightly bent due to the misalignment. FYI. the pushbutton controls were not flashing.
How I can open up the latch on the passenger side so that I can manually lift up to top just enough to set both pins aligned with the holes? Right now, it leaks on the driver side whenever it rains. FYI. Both fuses are still good.
Please help.
Thanks.
Mini Al
Please help.
Thanks.
Mini Al
