2008 Cooper Base idle issue
Diagram #17
RealOEM.com - Online BMW Parts Catalog
https://www.ecstuning.com/Search/Sit...419/ES2675556/ x 1
then
https://www.ecstuning.com/Search/Sit...932/ES2672724/ x how many wire you have
Then the gommet x the number of wires, this seals the wire to the plug .
https://www.ecstuning.com/Search/Sit...411/ES2673549/
Strip the wire of wire back a bit, you have some room/ slack in the harness. Then cut and reclip the ends.
then
update. I think I found the source of the oil pressure light issue. The plug in for the sensor has a tab the goes over a tab on the sensor, and keeps it in place. That tab was bent up, and was sliding over the tab on the sensor when the motor would heat up. That plug in pulled right off with no resistance. Old age and plastics I guess.
My solution? Inserted a shim to keep that tab pressed down, and keep the plug in in place. No oil pressure warning light since. Idle still drops, no rough running or noticeable misfire.
pauldixoninohio
Nov 18, 2015 12:16 PM
sirfrank
Sep 11, 2015 03:08 PM
