2010 Mini Cooper S throttle body change
Old Apr 22, 2016 | 08:24 PM
phatthawg's Avatar
Default 2010 Mini Cooper S throttle body change
So I have a 2010 Mini Cooper S that is kicking throttle body codes and going into limp mode. My questions are:
A) How can I tell if it is truly the throttle body that needs replaced?
B) If I do replace it on my own, will I need a dealer to reprogram if I buy a new one?
C) If I buy a used one, will I need a dealer to reprogram?
Old Apr 24, 2016 | 02:20 PM
phatthawg's Avatar
Seriously, not 1 response?
Old Apr 26, 2016 | 01:22 PM
PelicanParts.com's Avatar
Post the P codes when you can. According to the Bentley Manual, you'll need a MINI scan tool to reset the ECM memory and reset the throttle plate adaptation values.
Old Apr 26, 2016 | 03:12 PM
phatthawg's Avatar
I have a mini scan tool. and have cleared the codes once but am waiting for the new throttle body to do it again. Almost every code was throttle body value too high, then too low, then permanently stuck.
Old Apr 26, 2016 | 03:14 PM
phatthawg's Avatar
Thanks for the response, btw. When you say mini scan tool, do you mean a Mini Cooper specific scan tool?
Old Apr 26, 2016 | 03:50 PM
Yes, a MINI/BMW specific scan tool. Not a generic one. The throttle body can get gummed up and cause some issues. If you get the codes again be sure to post them up.
Old Apr 27, 2016 | 12:32 PM
phatthawg's Avatar
I cleaned the original throttle body and reinstalled it with no luck. Installing one from a donor car possibly tonight. Hopefully this will fix it
Old Apr 27, 2016 | 05:38 PM
  #8
phatthawg's Avatar
Cleared codes again with a generic scanner, swapped the throttle body with a donor. Problem is gone and running like a champ again. Thanks for your help Pelican parts!
Old Apr 27, 2016 | 05:40 PM
  #9
Great to hear! Happy motoring!
sixcard
Dec 14, 2012 01:17 AM
jimmybuffett
Jan 7, 2011 01:31 PM
bballplayer39
Jun 21, 2009 03:47 PM
chileoggie
Jan 21, 2009 09:54 PM
