2010 S New- Engine doesn't start at times
Old 12-08-2010 | 03:49 PM
warterated's Avatar
Default 2010 S New- Engine doesn't start at times
My 2010 Cooper S I purchased last June won't start every now and then. Press break and start button it just beeps and blinks then nothing. The engine doesn't rev. I've had this problem from the very beginning when I purchased the car. I'd say once in 6 times starting the car I get this problem, more often when I drive a short distance to run quick errands and trying to start the car again after a few minutes.
Took it in to the dealer but they said they couldn't "duplicate the problem". Any idea what's the issue?
Old 12-11-2010 | 02:12 AM
Spiderbob's Avatar
Intermittent problems dealing with sensors, computers, etc. are usually a loose ground. Start with the battery, remove the terminals (that will also totally reboot your computer) clean them good and put it back together. Then check all your grounds, there are quite a few of them. I have not seen a wiring diagram for 08 and above, so you’re going to have to look around.
Old 12-11-2010 | 09:21 PM
Auto or manual ? I'm thinking it might be the tranny switch or clutch switch not making
Matthew Jones
07-22-2015 12:19 PM
projectman
06-29-2015 09:37 PM
haleyjoe
03-01-2014 02:09 PM
LeaRoberts
01-10-2012 07:10 AM
choiboi
09-01-2008 09:45 AM
