AC blowing hot
Old Jul 13, 2019 | 10:00 AM
Christopher Roy's Avatar
Default AC blowing hot
Hello everyone,
i searched the forum a bit but did not find the answer i was looking for. I have a 2012 Countryman that is blowing crazy hot air out of ac system. i checked the fuse for the compressor with a multimeter and it was fine. i also heated the fuse and rechecked to ensure it wasnt breaking connection when heated. The air is blowing very well so its not a matter of the cabin filter being bad (i dont think). I purchased the A/C Pro 134a refrigerant kit and follwoed the instructions to a T. The issue is that when i attached the pressure gage portion of the kit to the low pressure port, the pressure indicator went into the red. I have heard from others that you can shoot a bit of coolant and the pressure will read correctly but i didnt want to chance just in case. Does anyone have any ideas on what i should do? Thank you so much in advance for all your help!!!
chris
Old Jul 4, 2022 | 03:20 PM
Usernameghost's Avatar
Did you ever figure this problem out. I’m having the same exact symptoms and your the only person I’ve seen post about this issue
Old Jul 9, 2022 | 11:28 PM
BULLDOG85043's Avatar
Having the low side in the red while the car is running and the AC turned on fill usually means 1 of 2 things. First is there's a blockage and the pressures have balanced betwenhi and low side. Second is the system is over pressured. In both cases, unless you have a way to recover the gas, you're looking at a visit to your local mechanic. If it's a blockage, it's most likely the orifice tube (not sure if the Mini uses that) or the expansion valve is toast.
jbsamock
Apr 17, 2017 09:29 AM
downwardkick
Jan 12, 2017 11:19 AM
martyde123
Jun 19, 2011 11:09 PM
daniellowitz
Sep 6, 2010 11:25 AM
ramirez01
Aug 25, 2010 10:28 AM
