Cylinder Misfire
Old Jan 14, 2022 | 09:02 AM
Alternet's Avatar
Default Cylinder Misfire
So I will try and keep this short.
A Few days ago my car threw an engine code. Cylinder one Misfire.
I Swapped coil one and coil two.
Cylinder two Misfire.
Great, the coil is bad. I replaced the coil.
After the coil is replaced, i drive the car. The Car feels better then it has in awhile.
Two days of driving later, i get an engine code. Cylinder one Misfire.
On top of that i'm getting codes P2781 [ECU7E8] (Downshift Switch Circuit high) and P2771 [ECU 7E8] (Four Wheel Drive Low Switch circuit)
My car is a 6 speed stick, not automatic.
Do I have a bigger issue or did I just get unlucky and have two coils fail close together?
k_van10
17
Aug 17, 2021 11:03 AM
Toolman5862
Dec 12, 2020 04:29 PM
ricsonham
Aug 3, 2017 04:51 PM
ShewbodMini
Feb 11, 2011 06:11 AM
