Engine management light
Old Nov 9, 2018 | 07:07 AM
Nath's Avatar
Default Engine management light
So for a while now I've been getting my engine management coming on. I have my own OBD reader and it says
P0420
Catylist system efficiency below threshold bank 1.
googled it and it says.
the P0420 code stands for “Catalyst System Efficiency Below Threshold (Bank 1).” When you receive a P0420 code it means your catalytic converter is not operating at maximum efficiency. Usually this means your catalytic converter needs to be replaced or there is a problem with your O2 (oxygen) sensors.
This keeps coming up. My garage has checked it out and the converter passes the emissions test. I've had both lambda sensors changed and the oxygen sensor. Should I just resign myself to a new catalytic converter.
Thanks for your help
Nath
Nov 6, 2018 06:36 AM
Swainscalf
Jan 6, 2018 08:53 AM
Swainscalf
Jan 6, 2018 01:42 AM
timthechef
Mar 11, 2017 02:00 PM
fordman808
Jun 4, 2008 02:14 PM
