Hatch Lock Problem
Most of the threads about the hatch lock seem to be inoperability. The problem with mine is that it spontaneously pops open at inopportune times. Usually, it will pop open when I start the car. Then I have to get out, shut the hatch, and then start driving. Sometimes it just pops open after I stop and shut off the engine and then open and shut the hatch. It sometimes just pops open again.
I checked the hatch mechanism and it opens and shuts appropriately when close the latch with a screwdriver and then actuate it with the hatch button. Doesn't appear to be any binding or debris in the way, and all looks clean. Any clues from users here? |
Originally Posted by cgpiper
(Post 28912)
Okay, I'll try an interim fix and see if re-soldering and cleaning the switch helps (the rubber portion is totally gone, so the switch as culprit makes sense since it's been exposed to the elements for a while). If this doesn't work I'll replace the switch itself and only go for a new (expensive) handle as a last resort. Thanks for the tip!
Hope it works!
I took the safe way out and bought a new OEM hatch module. All is well. But I’m still going to try and repair the original one as a possible spare.
