I need help... I can't open the hood.
Old Jul 3, 2018 | 03:18 PM
sbrown712's Avatar
Default I need help... I can't open the hood.
The hood release doesn't work. I don't know if the cable broke or if it is just disconnected from the release under the hood. Does anyone know how I can get the hood open without taking the front of the car apart?
I would really appreciate your help.
Old Jul 4, 2018 | 08:39 AM
Heath Slaton's Avatar
Default Hood release
You can try pressing down on the hood while someone else pulls on the hood release inside the car. If that does not work, you will need to determine which latch is not releasing as there are 2 latches in play. If the driver’s side latch is not releasing, and your car has a turbo charger, you may have to take the front of the car apart to get to it. Otherwise, you can try using a long, bendable piece of metal that is small in diameter to push up from underneath the car to press on the latch releases on the side of the front of the car that is not releasing and open the hood. I have used this method before with success. It is a very tedious process.
Old Jul 5, 2018 | 04:52 AM
sbrown712's Avatar
Thanks for the suggestion. Now I just have to find someone to help.
sbrown712
Feb 6, 2018 08:28 PM
seth2002
Feb 22, 2017 03:41 PM
vette40509
Mar 8, 2014 09:41 AM
vette40509
Mar 8, 2014 08:02 AM
Flash
Jul 5, 2007 03:44 AM
