Low Tire- indicator and other indicators
Old Sep 12, 2017 | 11:27 AM
huma.thekedar's Avatar
Default Low Tire- indicator and other indicators
Hi,
I always keep getting Low Tires Indicator in my 2009 Hardtop Mini even though the air in the Tires are full. Have anybody else encountered this.
I also got an indication today with the car on the stand which went away after some time. When i read the manual it means the Vehicle engine is failed and the car should be taken to the mini dealer immediately.
Is there some problem with Indicator sensor?Please Helpconfused:
Old Sep 25, 2021 | 01:21 AM
Nzr56coopers's Avatar
Hard to explain how to reset your system by this means,I had the same issue.search YouTube for tyre pressure reset,videos will explain the easy way and you can watch over again I did,also have a look at YouTube hidden mini features some cool stuff to learn about the car.
Old Sep 25, 2021 | 07:41 AM
bdsnooks's Avatar
I have a 2009 mini s, just replaced my sensors… I was told the batteries in them are only good for about 10 years. After sensors replaced it works great.
Old Oct 4, 2021 | 06:01 PM
Osborn's Avatar
Originally Posted by huma.thekedar
Hi,
I have the same issue with my 2011 CooperS. I was told that each wheel has a sensor in it. These have batteries that are worn out and not replaceable - in other words, you have to replace the whole stem. What's worse is that you don't know which one is causing the fault.
Jessie
Sep 25, 2021 01:22 AM
Mini-Mam
Sep 25, 2021 01:17 AM
Vito
Sep 19, 2021 08:47 AM
sixandtwentyone
Dec 12, 2011 11:50 PM
lynmcki
Apr 11, 2008 12:59 PM
