-   -   Mini cooper s turbo wont start unless a disconnect high pressure fuel pump plug, 2 wi (https://minicooperforums.com/forum/07-up-mini-cooper-cooper-s-r56-31/mini-cooper-s-turbo-wont-start-unless-disconnect-high-pressure-fuel-pump-plug-2-wi-12856/)
Baileyboy2008 Jun 29, 2021 04:04 PM
As per title any ideas, car just cut out dead and will not start unless I pull the 2 wire plug off the high pressure pump solenoid. I also get no reading at all on the dianostic fuel pressure check. I have 72 psi when connecting my fuel pressure gauge to the line.
Nzr56coopers Jun 30, 2021 10:40 PM
Sounds like a solenoid issue,pump has plenty of pressure,it's not sucking air from a fuel line clip leaking is it.
