Mini cooper s turbo wont start unless a disconnect high pressure fuel pump plug, 2 wi
Old Jun 29, 2021 | 04:04 PM
Baileyboy2008's Avatar
Default Mini cooper s turbo wont start unless a disconnect high pressure fuel pump plug, 2 wi
As per title any ideas, car just cut out dead and will not start unless I pull the 2 wire plug off the high pressure pump solenoid. I also get no reading at all on the dianostic fuel pressure check. I have 72 psi when connecting my fuel pressure gauge to the line.
Old Jun 30, 2021 | 10:40 PM
Nzr56coopers's Avatar
Sounds like a solenoid issue,pump has plenty of pressure,it's not sucking air from a fuel line clip leaking is it.
Jyobeb
Jul 3, 2021 01:35 AM
saxtell74
Mar 22, 2021 08:41 AM
sremenap
Jan 11, 2020 07:48 AM
Frank Mendez
May 24, 2018 11:16 PM
Matthew Vary
Feb 13, 2017 05:03 PM
