Oil Filter Info Needed
Old Aug 30, 2010 | 07:18 PM
kmwatersaz's Avatar
Default Oil Filter Info Needed
Recently saw a Wix filter # 57303 as ok for the 07 mini cooper in a parts store book. But then on a wix filter website, the same filter is listed as good for up through 2006. Can someone out there clear this up? And suggest any other oil filters by brand and product code? Thanks.
Old Aug 30, 2010 | 07:54 PM
I know the 2 are not intechangeable ...
NAPA has both ones different numbers ...
Old Aug 31, 2010 | 08:49 AM
kmwatersaz's Avatar
Default Oil Filter
thanks. I will research further. I can't find an engine code number so maybe I need to go to a mini dealer.
Old Sep 13, 2010 | 06:17 PM
CincyMINI's Avatar
The engine codes for Cooper is N12 and for the Cooper S N14.
02-06 Filters are not able to be used in the 07-10 MINIs in any way.
The BMW Part Number for the filter you need is 11-42-7-557-012. Good luck!
Old Sep 14, 2010 | 08:11 AM
kmwatersaz's Avatar
Thanks. Got it figured out. Checker Auto shows 2 filters in their system for the '07 Cooper coupe. For 2 different engine codes. The second one I tried is the right one. I guess I have the N12B16A. So the Wix number is 57512. Don't be fooled by the wix website. If you put this wix number in you get the Clubman. I don't have a Clubman, but this is the right filter.
KLT55
6
Apr 16, 2011 08:28 AM
KLT55
Apr 13, 2011 08:52 AM
jball
Dec 2, 2009 04:15 AM
calxen61
Mar 2, 2009 04:26 PM
Coopermini
Oct 17, 2008 08:51 PM
