R56 cold start no throttle response
Old Oct 11, 2020 | 08:16 AM
Bobby Briggs's Avatar
Default R56 cold start no throttle response
It seems I have a very common problem, but have yet to find a posting with a resolution. My 2008 Mini S went to my mechanic with the familiar cold start problem,...it starts right up, but acts like its not getting enough fuel. There's no throttle response, and does a misfiring idle. If it doesn't die, I restart it a couple times and it runs great from then on. I just got it back yesterday with no codes, and 'ready to go'. I had brought it to mechanic 8 weeks ago with this problem, after I purchased the car a week before. He originally suspected low fuel pressure, or a problem similar to a weeping check valve letting the fuel drain down over night. Upon his inspection, they found a bit of antifreeze in the head, and went with the theory of it being a bad head gasket. Upon breaking down the engine, they sent the head out to be pressure tested. It was fine, but they planed it, and did a valve job since it was there. My tech then replaced all the timing components, thicker head gaskets, and reassembled.. Upon starting it, they found several codes of misfiring, and began chasing them down. So I now have new injectors, new coils, spark plugs, water pump, intake manifold, valve cover, and still have the same original issue!! GAHH!!! I've now spent more than I paid for the car and have the same issue. I do not want to take it to the dealer and have it tied up for months again, and spend another small fortune, or continue frustrating my mechanic grabbing at straws.
Has anyone found a working resolution?? Thanks in advance! ~Bob
Old Oct 11, 2020 | 10:02 AM
bdsnooks's Avatar
Going through same thing....turns out it’s a bad fuel pump. High pressure side. Same symptoms as yours. Being repaired now and I will advise how it works ASAP. Pricey pump!!!
Old Oct 11, 2020 | 11:03 AM
Thanks for the input! It’s been my fear that the pump is pretty common and may be part of the issue. Appreciate it. Please let me know how you make out!😉
Old Oct 11, 2020 | 11:22 AM
bdsnooks's Avatar
Should get pump by Tuesday...I will post results probably Thursday...
Old Oct 15, 2020 | 05:39 PM
bdsnooks's Avatar
Default Pump
New pump installed.....PROBLEM SOLVED!!!!!!
Old Oct 28, 2020 | 06:31 PM
It WAS in fact my HPFP. So glad these forums are here ;-)
YouTube videos were quite helpful on the install. I had it done in less than an hour!
Tonydec
Feb 20, 2023 11:11 PM
30roadster
Mar 25, 2019 10:03 PM
HasAnMTBProblem
Jul 19, 2017 06:30 AM
DontCountToday
Apr 10, 2017 05:50 AM
bogus
Dec 6, 2008 12:49 PM
