r56/n14 Valve Replacement Recommendations
Old May 10, 2024 | 01:40 AM
Bloopdog's Avatar
Default r56/n14 Valve Replacement Recommendations
Hello all. this is going to be my first post here! Recently picked up a 2009 Mini Cooper S with 139000 miles owned by a mini master tech! It has been super great to me and ive taken it on 500+ mile road trips a few times since owning it. However around a week or two ago I took it to a town near me, about an hour into the drive I got a blinking CEL and a very apparent misfire/lack of power. Against my better judgement and other circumstances, I drove it home staying out of boost (it took forever i must add). Tore it down a bit and did some basic diagnosis, new plugs, moved coils around to see if misfire moved. Had a code for a random misfire, cylinder 1,3,4 misfire, and p115c. cleared and only cyl 3 misfire code came back, with an obvious misfire coming from 3. compression test revealed 3 was toast, tore head off, found hole in an exhaust valve! I am decently mechanically inclined (or naive) and someone confident I can get it back together with some guidance. What I am not confident on: (this is where the questions start)
cylinders look great from what ive seen, no odd scoring, no obvious wear, cannot feel anything. pistons look good with some buildup. headgasket looked pristine, plugs looked good, and really nothing looked super bad other than a lot of carbon buildup on valves.
1. What should I replace while im here? This car was maintained GREAT with reciepts before i bought it. gaskets looked good, no leaking from anything.
Do I replace just the valve, its keeper, and guide, with an oem replacement and slap it back together with a headgasket kit?
2. Are there any better valves I can buy that can prevent this from happening again (why did it happen in the first place?) that arent crazy expensive?
3. I'm finding full sets of intake and exhaust valves for 50$ and up to 500$ ? what are the differences and should I just buy the cheaper ones.
4. following number 3, should I replace ALL the valves, ALL the guides, ALL the seals, or just the problem ones? Would it be cheaper in the longrun than having it walnut blasted or trying to clean the buildup myself?
5. Are there any "UPGRADE THIS GASKET, UPGRADE THIS BOLT, BUY THIS BILLET PART, DO THIS CERTAIN HEADGASKET, DO THESE VALVES WITH THIS SEAL!!!!" type recommendations that arent break the bank type that are definitely a worthwhile peace of mind investment?
ideally i want to get this back together and know it will be okay, but also not spend a whole bunch of money going down the rabbit hole of "while im down here", because that only stops when the money runs out.
From what i can tell the head doesnt need machining, but from my understanding new valves will need to be lapped to seal properly?
califresh119
Mar 19, 2025 12:50 AM
stokestack
Jul 7, 2020 09:36 PM
KusoBabA
Nov 13, 2019 06:11 PM
EMPIR3
Jul 22, 2019 10:46 AM
colonelangus
May 19, 2019 10:27 AM
