passenger side clbman re barn door will not stay closed
Old 12-29-2017, 08:15 AM
Shane Jones's Avatar
Default passenger side clbman re barn door will not stay closed
the latch is not stuck closed. the door will not stay shut. any ideas or is there a way to check if its the latch verses something electrical?
thanks
Old 02-18-2018, 06:29 PM
PhatBrian's Avatar
Member
use a screwdriver and see if it latches and unlatches when you hit the switch. if the latch is all wobbly its probably the lock actuator itself. its probably the actuator.
islandguy808
05-04-2019 02:57 PM
Ikestr96
02-18-2013 08:05 PM
perkman
09-06-2008 08:34 PM
revy_ajax
08-06-2008 04:29 PM
Sharkfyn
05-20-2008 03:58 PM
Quick Reply: passenger side clbman re barn door will not stay closed
