Break Pad Light (tried all things found on forum) - HELP
Old Mar 27, 2013 | 08:17 AM
AND4848's Avatar
Default Break Pad Light (tried all things found on forum) - HELP
My mechanic has told me that he has replaced front and rear pads when doing the breaks. Also tried 2 sets of sensors and cannot get the light to go off.
I have tried all the things found on the internet. Playing with the dash tests, key in 2nd position with foot on break. Nothing seems to get the light off.
My mechanic said he thinks maybe it's something wrong with the computer and could investigate if I wanted him to.
My question is, is there anything else I can try? Is there a chance, he has not replaced the sensors? Thanks!
Old Mar 28, 2013 | 07:45 PM
The Sensors are clipped in the pad.
When the pads wear thin , the sensor rubs and breaks the circuit,
They are basically just a wire folded and then cuts it when worn.
Have you checked break fluid ? Low fluid can trigger light as well.
Old Mar 28, 2013 | 10:22 PM
gruss's Avatar
Member
Have you driven it a day or two since the sensor was replace? I have seen the light reset after driving for a few days.
Old Mar 29, 2013 | 08:23 AM
AND4848's Avatar
I've driven it a while. Mechanic seems to think either they are bad sensors or the computer is malfunctioning. I'm going to get in there this weekend and check the connections.
Old Mar 29, 2013 | 05:40 PM
if you have the old sensors cut them and strip back the wires and connect them together and plug that in and see if the light clears
you can also check the sensors with an ohmmeter
spencerbrog1
Jun 16, 2012 04:47 PM
reynold22
Jun 15, 2012 02:29 PM
jamey
Dec 22, 2010 08:12 PM
chicagomini
10
Jan 15, 2008 01:53 PM
May 23, 2005 10:57 PM
