Drivers door "stop"
Old May 21, 2013 | 01:52 PM
tkendall's Avatar
Default Drivers door "stop"
2004 Mini, the drivers door just recently stopped being held ajar, when getting in or out of the car. Normal is two positions where it will stay open, but now getting out of the car, (or in) can result in being banged on the shin with the bottom of door. Any ideas on a fix?
Old May 22, 2013 | 10:00 AM
Its the door brake that is located up by the hinges. One for each front door. Can be used on the left and right side door.
There is an early type : MINIs with production to 5/2003
http://www.ecstuning.com/Search/51211166471/
There is an later type : MINIs with production from 5/2003 on.
http://www.ecstuning.com/Search/51217176811/
Just match up what you have to the pic and you are good.
Old Jun 5, 2013 | 10:56 PM
gruss's Avatar
Member
My wife's 02 had the same problem. They sell for about $51, so I swapped the passenger side to the drivers side. You have to remove the door panel, but its fairly simple to do. I have the old style and it took a 8mm socket for the bracket to the door frame and I think a Torx T25 for the bracket to the door.
Old Jun 10, 2013 | 09:25 AM
+1 Yep,
Just match up the design from the ones up top and you should be gtg. We have the links above the pics. There is the older style and newer style.
While you are at it you can spray penetrating oil #2 and #3 to help the door swing.
Old Jun 12, 2013 | 03:47 PM
tkendall's Avatar
Thank you, I was thinking of trying that and now I will.
Old Jun 18, 2013 | 09:01 AM
You are welcome.
nhusa
Oct 30, 2014 09:44 AM
Jun 13, 2014 02:00 PM
asifallasleep
May 21, 2012 12:09 PM
Copboy4090
Dec 4, 2008 03:51 PM
LETSMTR
Oct 8, 2008 02:14 PM
