Geartag 6spd swap issue/queestion
Old Sep 17, 2024 | 10:05 AM
mrminid's Avatar
Default Getrag 6spd swap issue/queestion
Hello,
I am in the process of swapping an R53 6 spd Geartag into my R50,
So far the process has been pretty smooth but I have came across an issue and I can't find anyone else posting about it.
I mated the 6spd with the engine, attached the shifter cables (from another R53) and when I raised the transmission up to mount it, the shifter cables are very close to the AC line going under the battery holder bracket. In fact, once the tramissions is raised, I am unable to shift the gear into 2,4,6 or reverse because there is not enough clearance for the shifter.
Has anyone ran into this? I am at loss here. Any help would be appreciated.
Pictures below show the issue
Old Sep 19, 2024 | 11:19 AM
mrminid's Avatar
Turns out after bolting everything down, there is just enough space for the sifter cables to go through into every gear.
Pokeypavnoz
Jul 7, 2023 09:25 AM
dcnaz1973
Jun 15, 2022 07:14 PM
John OKC
May 23, 2017 02:44 PM
quacooper
Dec 15, 2015 04:54 PM
May 15, 2015 05:45 PM
