ignition problem
Old May 25, 2023 | 03:59 PM
Ray Lagasse's Avatar
Question ignition problem
2003 Mini Cooper s originally had a fuel problem, now thats fixed now I have an ignition problem I have voltage at the center contact of the coil but no spark at the spark plug, does anyone have a schematic that might help me figure out my problem ?
Old Aug 27, 2023 | 02:07 PM
NVmini's Avatar
It's actually a ground pulse from ecm that tells the ignition coil(s) to spark...12VDC power will always be applied with key in run position (even if your ecm and ews have lost sync). I had the same issue, but with cylinders 1 and 4 only...turned out to be a bad/burned contacts inside ECM (DME) that supply the ground pulse to the coil. Very difficult to repair, even with good soldering experience. Real easy inspection to do by simply opening up ecm module.
If possible, a good first check is to ensure your crank trigger is working by watching with a live data scanner as you crank over the engine...this is where it all starts.
Might want to throw in there...could be as simple as a bad coil...but usually (on GEN 1 Mini's) they will give you issues with either cylinders 1 and 4 or 2 and 3 first if in fact a coil (step up transformer) is beginning to fail.
Start with the simplest and cheapest stuff first...
jamesminime
Feb 26, 2022 09:30 AM
Gustahvo Rivera-Martinez
Dec 7, 2019 04:13 PM
Oct 4, 2013 06:30 PM
eMpire
Aug 19, 2011 07:37 PM
