ignition problem
2003 Mini Cooper s originally had a fuel problem, now thats fixed now I have an ignition problem I have voltage at the center contact of the coil but no spark at the spark plug, does anyone have a schematic that might help me figure out my problem ?
Originally Posted by Ray Lagasse
(Post 29936)
If possible, a good first check is to ensure your crank trigger is working by watching with a live data scanner as you crank over the engine...this is where it all starts. Might want to throw in there...could be as simple as a bad coil...but usually (on GEN 1 Mini's) they will give you issues with either cylinders 1 and 4 or 2 and 3 first if in fact a coil (step up transformer) is beginning to fail. Start with the simplest and cheapest stuff first... |
| All times are GMT -5. The time now is 06:40 AM. |
