Instrument Panel lights won't turn off
Old Sep 6, 2011 | 09:00 PM
jmarcus's Avatar
Default Instrument Panel lights won't turn off
Hi,
A rainy day here in Boston. When I got home and shut off the car the instrument panel wouldn't turn off. I noticed when I open the door, it bings as if reminding me to turn off the lights or that I have left the key in the ignition. I started the car again and drove it around the block, nothing changed. I turned the lights on and off, and I flipped most of the switches.
Any thoughts short of disconnecting the battery?
I have a 2003 Cooper S
James
Old Sep 7, 2011 | 05:49 PM
check the relay that controls the lights might have fused or a bad light switch
Old Mar 24, 2018 | 09:30 AM
Michele Marongiu's Avatar
Default Some Problem
Hi, have you solved in any way?
I have the same problem!
Old Mar 24, 2018 | 09:38 AM
Old Mar 3, 2022 | 06:40 AM
Scoobyfan's Avatar
Default Mousture
Originally Posted by jmarcus
Hi,
James
make sure your fuse box is dry and check wire for corrosion. Ya probably way late on this answer. Sunroof drains like to spring leaks and ofcoarse they run inside the car and straight down to the electrical.
Old Mar 22, 2022 | 08:46 PM
minicooper56's Avatar
i have one more issue then this my head lights and high beams wont work and the parking and indicator light wont turn off any suggestions all i have been able to disconnect the battery
Old Mar 23, 2022 | 06:39 AM
Scoobyfan's Avatar
check the back of your fuse panel for corrosion,check relays for the headlights and possibly your headlight switch.. cant say for sure if its any of these but its what comes to mind at the moment. I dont know all to mutch about the headlight setup on these minis its different from what im use to but if i have any other ideas ill jot them down.
Mini JJ
Nov 7, 2020 02:06 PM
scienceesl
Aug 24, 2015 11:37 AM
Budroe
Oct 30, 2014 09:49 AM
BlackCatGuy
Sep 10, 2011 05:31 PM
halpernjs
Dec 23, 2008 08:09 PM
