Just another A/C post!!!
2003 Mini Cooper!!
Current Symptoms. 1. Light on A/c Switch on solid (no blinking) 2. Yes, I can hear the compressor turning on/off 3. Low speed fan does not turn on when A/c is turned on. 4. When I attempt to recharge the R123a i get half way and the high pressure dump valve on the compressor opens. A/c stopped working by dumping the refrigerant out the port on the bottom. During troubleshooting I found out the my low speed resistor was shot. Replaced!! I tested afterwards by jumpering the battery to the connector pins and fan worked in both speeds. I recharged with more r123A but didn't get halfway through the can and it dumped again. I noticed that the fan wasn't operating. Since I replaced the fan resistor I expected the fan to turn on when the A/c is ON, correct?? I don't want to waste another can of r123a.....should I recharge or will it dump again? Should the fan be ON with the A/C on? What else should I do? Thanks Doug |
| All times are GMT -5. The time now is 06:39 AM. |
