Mini Cooper light problems
Old Jul 4, 2013 | 11:49 AM
Runetamer's Avatar
Default Mini Cooper light problems
I have a 51 plate r50 Mini Cooper that is having issues with the lights, the main beam randomly flickers on and off. I have fitted second hand lamps today to the car after hearing they could of been the issue, it hasn't solved it....any suggestions? If this is in the wrong section I appolgise
Old Jul 4, 2013 | 02:19 PM
gruss's Avatar
Member
If you replaced the lights then you may have a connection issue. Do the lights flicker on rough roads or on any road?
Old Jul 4, 2013 | 04:02 PM
Runetamer's Avatar
It done it with old lamps, so changed them thinking it would help but nothing.
It does it randomly, like it'll do it then stop for abit then start again
Old Jul 9, 2013 | 02:42 PM
gruss's Avatar
Member
Loose or corroded connections or fuse? Definitely the poser source.
Aug 21, 2015 03:00 PM
Aug 21, 2015 02:49 PM
Michael Lytle
May 26, 2014 07:08 AM
LiveMini22
Oct 10, 2013 06:44 AM
imdakine1
Aug 7, 2008 04:09 PM
