P2127 and P2138 Check Engine Light codes
Hello, everybody,
I purchased a Mini Cooper "Diagnosis Without Guesswork" manual for my car from Bentley Publishers, it seems like this manual has all the codes and diagnostic steps EXCEPT for the two I need. I'm getting the following two codes together, and I'm looking for what to fix: P2127 - Throttle/Pedal Position Sensor/Switch "E" Circuit Low P2138 - Throttle/Pedal Position Sensor/Switch "D"/"E" Voltage Correlation When these codes started, the car lost about 80% of it's power in any gear above 1st. It felt like the car lost about 10% of it's power two months ago (about the time I had transmission work done), but no CEL came on, and I wasn't completely sure. I see a YouTube video for a Nissan with those same two codes, and it was corrected by cleaning connectors to the throttle position sensor with canned air - I'd try this, but I can't figure out how to get to the Pedal Position Sensor for my Mini - it's the "block" behind the gas pedal, right? Mini Cooper (non-S) (R50) 2006, hardtop Any help would be appreciated. This manual is a $100 paperweight (rush shipping). Any ideas? Thanks! |
| All times are GMT -5. The time now is 09:13 AM. |
